Clutch slipping?
Need more info... How many tanks run? Any modification to driveline or lager motor?
Your broke you have a bearing going bad look around check drive shafts and there pins
There is a drive pin broken if it barley moves or wheel is lose sorry if mistakes on typing don't have glasses on check rear diff gear ill bet case is melted look for bearing sticking out of case
1. Do the wheels spin freely by hand?
2. Does the truck move easy by pushing it, if not center diff might have a rock or something jamming it
