Where to buy bearings for 5b
SidcupChap
Hi Everyone, Just a quick one. Can someone tell me where to buy the small bearings located inside the steering tubes, the tubes are just in front of the servo electrics box. Many Thanks
Agreed, as mentioned above.
General consensus is rubber sealed seal better - keep the dirt out better - but may not be as free-running as metal shielded.
If it's an inner / protected bearing, or you're running in clean areas - UNLIKELY!! - then metal will be freer running.
Al.
Al I've seen metal let fine dust in
Al.
I've had metal ones let fine dust in so I always use rubber to be sure to be sure.
I haven't seen any difference in performance between them.
