SidcupChap
Hi Everyone, Just a quick one. Can someone tell me where to buy the small bearings located inside the steering tubes, the tubes are just in front of the servo electrics box. Many Thanks
Try your local bearing shop.Hi Everyone, Just a quick one. Can someone tell me where to buy the small bearings located inside the steering tubes, the tubes are just in front of the servo electrics box. Many Thanks
Thank you, i will try them now.Fast Eddie bearings, they got them all.
Agreed, as mentioned above.
General consensus is rubber sealed seal better - keep the dirt out better - but may not be as free-running as metal shielded.
If it's an inner / protected bearing, or you're running in clean areas - UNLIKELY!! - then metal will be freer running.
Al I've seen metal let fine dust in
I've had metal ones let fine dust in so I always use rubber to be sure to be sure.Agreed, as mentioned above.
