James H.
Active Member
Im curious about the Front Toe Adjustment on my DBXL.. The book shows the measurement at 49mm for the Turnbuckles. Using this measurement gives the front tires a "Toe-in" setting, yet the manual clearly states to "NEVER RUN FRONT TOE-IN" I have had an issue getting my front steering set correctly. Its almost just right, but i have the settings in my radio set at points that just seem like way too much of an adjustment.. I have my end points set and everything and the servo was centered when first set up.
Im wondering if anyone knows anything about this. Should i be adjusting for more of a Toe-out setting? Just odd that the book shows a setting that gives it a Toe-in as standard, yet it says to never run front toe-in.
Any Ideas???
Any Ideas???
