Help with ignition system
Z.hb71
Build Thread Contributor
Ok how would I splice/add in a on/off switch into my custom ignition system? If it's never going to work how should I redesign it? Like make me a diagram plz, i have really no idea on that would work because I'm uneducated when it comes to makeing custom circuits and stuff and I really don't want to burn my truck down. This is the diagram and I don't know where to add a off/on switch so could someone tell me?
Are you talking about an on/off switch for your electronics or a kill switch on the engine?
Was Gunna use a Dynamite with the super bee boat end but I just decided to pay alittle extra and get a super bee. Haven't heard of them failing.
No because it's boat syle ignition and it's different. not sure on how a RC boat uses a of switch cuz I couldn't find any diagram or anything
The boat kill button wires up the same as a car kill switch, at least my 26cc hydroplane does
Could I see? My ignition system is this
The black wire attaches to the black wire on the kill switch and the ground ring obviously gets grounded.
Is it like a car with the coil? It should have 2 terminals on the side of the coil where the off switch should be connected. That is without the kill switch connected. Do you have any pics, Z??
That's wild. Never seen one like that. You should be able to wire the switch in series with the red wire. Just break the red wire from the coil and put the black wire of the switch on one side and the red wire of the switch on the other side.
Awesome thx. ? I'll do that. Do this? Not with tape obviously
What you need is this
Give me a couple mins and i will show you where to wire it in
Splice the wire in here and connect the switch15437131790642367999951780840768.webp
Then plug red wire in one side of the switch and the black into the other
