Vekta 5 - It Was My First Sucessful 45 Minute Bash
William E Burrows Jr
Florida
Since I converted the transmission with mega torque gears so I could run the Maxxis Tires, I have had nothing but drivetrain failures.
The short list: Transmission bell housing bearing destroyed.
Front differential housing, bearings, pinion and ring gear destroyed.
Internal gears in the rear differential destroyed.
I rebuilt all areas of failures and had my first successful 45 minutes bash run yesterday.
I cleaned it up and inspected and notice the front differential bearings had some slop causing play on the pinion gear.
I would suspect that will be the first thing to fail again. I will continue to bash and see how long I have until it fails.
"For Whom the Bell Tolls"
Best Regards,
William E. Burrows Jr.
Best Regards,
Nice ? hopefully it lasts
Congratulations (y)(y)
I just spent $150.00 on parts that I know will fail. I just rebuild my extra rear differential.
It was fun to rebuild it, but the differential oil was a trip.
See what a total differential failure looks like.
As a side note the KV2238 Vekta.5 Diff. Seal and Hardware Set. 4 of the 6 screws are the wrong size, I was able too use the originals.
I did report it to DDM.
Best Regards,
Best Regards,
Someone needs to make proper gears, and someone needs to stop selling those big ass tires as suitable for stock
It is nice too have your own parts department, I even have a complete stock transmission with upgraded brakes and the original tires.
If the failures keep happening I will convert back too stock.
The dual servos I think is a must, it turns on a dime.
I would think the steering would be even better with the stock setup.
Someday I will find out while I wait for my upcoming breakdown.
Best Regards,
