So I have a crappy $7 digital calipers and there not very accurate, most of the time .5-1mm off. So what are sum good ones? Not looking to spend more then 30 bucks cuz I don't see why spend that much.
Thxhttps://www.amazon.com/Gyros-DIGI-S...3FSJERZPXS9&psc=1&refRID=PNW2TVQP53FSJERZPXS9
This doesn't seem to bad . The one i use at work is over 200.00 with a cert .
Ok.I have a $300.00 mitutoyo caliper. And a $50.00 starrett. The mititoyo is way more accurate. But having said that the starrett is fine for anything rc.
+1 just need the basics
here is a pic of my ones used the for more the 10 years its all you need
I wouldn't care that much about accuracy but I'm building a engine as u know so I need accuracy.£10 ones here , they do what I want as I don't need accurate measurements when measuring the distance my front wheels to the rest of the car when I have a major spill...
J
Well I also need calipers. So I should get both.You need micrometers for that. Not calipers. I have a set similar to this. Got me buy for all the years I built engines for a living.
https://m.grainger.com/mobile/product/WESTWARD-Micrometer-Set-2YNC1?breadcrumbCatId=4008
Yeah, I'll need both cuz I'm pretty sure u can measure like inside diameter of stuff? And stuff like thatI have both. The micrometer is much more accurate then the calipers. If you know your not going to be measuring over a certain size you can just buy what size range mic. You need. The normally measure in inch increments ie. 0to1" 1to2" and so forth. I don't know what your trying to measure specifically so it's hard to say yes or no as to what would be good enough. If your figuring out what base gasket you need calipers are good enough. If you want to measure clearances you should be using mics. You may need snap gauges to measure the inside diameter of something too.
Will do.Yep get both. The caliper will get you close enough on most stuff. The mics will get you dead on for the stuff that matters
Thanks for the information! Also I think I could do $50 bucks for the calipers, any suggestions? I think I could probs get a used mitutoyoI was going to recommend Starrett or Mitutoyo but neither of them are in your set price range. Don't even think about Brown and Sharpe. The Husky brand with lifetime warranty no questions no receipt is choice for a budget caliper. I'd check its accuracy against a 123 block. Gage pins or gage blocks would be better but cost serious coin.
For inside bore get a set of telescoping gages. They don't need to be expensive, they just need to lock. If you don't know what they are or how to use them, youtube is your friend. They're really simple to use.
Like @Seandonato73 said a mic is going to be more accurate. Since you are building a small two stroke instead of a space shuttle, you can get by with a caliper and telescoping gage. When the radius of piston or any other round object exceeds the jaw length on the calipers, then you'll need to step up to a micrometer or long jaw calipers.
