Baja dies after 10 minutes
JACKDADDY83
Denver,Co
Does anyone have any good explanation why my Baja dies after 10 minutes of running? runs superb for 10 minutes then Dies as if it's flooded OBR 7.5 990 carb Thanks guys
Could altitude be a factor i live in denver 5280ft?
sounds like vapor to me. next it dies try loosening gas cap, if it starts that is your problem. that means the vent hole in gas cap is clogged up.
If it happens again pump your primer bulb if doesn't fill then your carb is getting too hot
Let us know when you fix it and the solution
Whats your needle settings
