- Thread starter
- #21
+1 for going through Dave's Motors. BEST in the biz! Hopefully some day they will get their Hostile tire manufacturing issues resolved and get those back in stock.
The pipe on your rig is the stock SS "tuned pipe". It's a modest gain over using the can that came stock on the non SS cars, but nothing to really write home about. The DDM Dominator is worlds better.
On Axle Extenders: I'm running the Darksouls on my truck and it's a quite a bit more stable in tight cornering situations. Not required, but certainly stabilizes these squirrely 2WDs. Less roll in high traction cornering. I also took off the rear sway bar. That helped a lot with reducing oversteer.
A good tuned pipe and better carb is the best thing you can do for the stock motor. I'm still running my stocker with a Walbo 990 carb, nice tuned pipe, and an adjustable clutch and it's a completely different car from stock. And it just...won't...die!
If you want to go up in motor without breaking the bank, you should save some bucks and get a g320RC. If you want to build it, you can just get a long block, 990 or 1107 carb, clutch housing, shroud and insulator, and transplant all the other parts from your stocker over to it. It won't save a ton of money that way (only about $50), but it could still be a fun project!
Big thanks for that detailed reply
I might save engine swap for winter project. ?⚙
What tire beeds do you suggest running, is there difference between options that you can buy or they all do rougly same job.
