"The clones"
Any reason they haven't added the XTM, Smartech & Firehammer? Even if its just the brand for now that would be nice? Hey that dang Traxxas got its own. J/k
I think the mods here are much more responsive and open to suggestions here than the other place.
Thanks for the ability to do things this way.
I like how the onroad section is broken down.
i agree a place for xtm/smartech would be great..i'm getting a grizzly in the mail this week and good info is hard to find..
I just traded for an XTM buggy. One of the best trades that I've ever made! It has a firehammer tuned pipe, alum rear shock tower, alum rear knuckles, firehammer filter, and 23mm hex wheel adapters. This thing is amazing and I love to drive it! It has plenty of power but I can't wait to upgrade the engine. Right now I'm running the proline beadlocks with moab tires. It gives it a little more ground clearance but still has plenty of low end.--nate
Hey Tom !
The XTM , did you or do you stock any alloy motor mounts ? my buddy's looking to get one possibly because of the price ..
Cheers .
It would be nice if someone else would carry the motor mounts for the XTM, Smartech and Firehammer buggy's it's really hard to buy from the only company that does right now!:(
Damn Right ..thats why i had to ask .. although i don't need any of those items but hate seeing people get jerked off buy the only seller around .. unless you go into the euro market ..
Tell me about it my 2 weeks turned into 3 weeks after I paid. I'm waiting cause who else can I get them from in the states - NO one- :mad: I swear there where 5 guys looking for them all at once you would think you would jump on a order like that!:rolleyes:
All of the FG tires and rims will bolt on a firehammer with no problem including Monster Tires
FG Part Numbers that work on the Fire Hammer. Some minor modifications may need to be done.
06011 Side guards l./r. each 1 pce. 18.59 18.59T
06023 Servo saver A/B, 1pce. 8.06 8.06T
06024 Servo saver pivot, 1pce. 4.55 4.55T
06026 Steering rods M4, 2pcs. 2.54 2.54T
06030 Steel balls 10 x 10,75, 4pcs. 8.97 8.97T
06031 Roll cage, 1pce. 14.30 14.30T
06032 Brace f. roll cage long/short each 1 pce 10.99 10.99T
06033 Wing mount, 1pce. 10.27 10.27T
06041 Pinion shaft 10 mm, 1pcs. 14.95 14.95T
06042 Brake plate and square, 4pcs. 13.78 13.78T
06044 Brake disks, 2pcs. 12.61 12.61T
06048 Steel gearwheel 48 teeth big, 1pce. 38.35 38.35T
06049 Clutch bell, 1pce. 37.05 37.05T
06050 Plastic gear carrier 60 mm, 1pce. 7.48 7.48T
06051 Dampening rubber, 4pcs. 5.40 5.40T
06061 Rear axle mount left, 1pce. 8.45 8.45T
06062 Rear axle mount right, 1pce. 8.45 8.45T
06064 Differential housing, 1pce. 16.12 16.12T
06065 Differential cover, 1pce. 6.76 6.76T
06067 Differential gearheel B, 2pcs. 35.04 35.04T
06068 Bevel differential gear axle, 1pce. 4.42 4.42T
06075 Rear upper wishbone pin, 1pce. 5.85 5.85T
06082 Gearwheel cover, 1pce. 5.85 5.85T
06096 Shock retaining screw M5, 4pcs. 6.31 6.31T
06099 Front shock mount, 1pce. 9.75 9.75T
06104 Front driving axle 55 mm, 1pce. 6.76 6.76T
06105 Wheel 1:6, white, 2pcs. 32.37 32.37T
06106 Square wheel driver 9.5 mm, 2pcs. 7.54 7.54T
06108 Off road tire stock M compound unmounted 55.77 55.77T
06116 RC-plate Futaba, 1pce. 10.66 10.66T
06135 Engine mount large, Zenoah/Marder, 1pce. 11.44 11.44T
06414 Tire inserts f.6108/6409/6411, 2pcs. 9.36 9.36T
06431 Steel gearwheel 16 teeth, 1pce. 22.75 22.75T
06540 Receiver box, 1pce. 8.58 8.58T
07088 Volume compensation f.shock absorb.,2pcs 3.06 3.06T
07089 Shock piston 2 pcs. 3.06 3.06T
07092 Spring plate 2 pcs. 3.38 3.38T
07094 Swivel nut M16x1, 2 pcs. 9.10 9.10T
07095 Adjustable ring 2 pcs. 9.10 9.10T
07102 Front wishbone pin, 2pcs. 7.02 7.02T
08092 Shock fastening pin/set collars 3 pcs. 3.19 3.19T
08097 Front axle trestle A, 96 1 pcs. 9.36 9.36T
08098 Front axle trestle B, 96 1 pcs. 9.36 9.36T
08140 Alloy plate for front axle 1 pcs. 10.01 10.01T
08348 Tank Solo complete, 1pce. 48.36 48.36T
06027/05 Ball-and-sock.joint 6mm f.M2screw thread 4.16 4.16T
06027/06 Steel ball 6 mm, 5pcs. 4.55 4.55T
06029/01 Ball-and-socket joint 10 mm f.M8, 4pcs. 6.37 6.37T
06072/01 Adj. rear lower wishbone 1:6, 1pce. 11.83 11.83T
06076/01 Rear up. wishb.thread rods r/l 61mm,2pcs 12.09 12.09T
06081/01 Ball 5/10x15 M5, 4pcs. 11.44 11.44T
06100/03 Turnbuckle right/left, 32 mm, 2pcs. 9.23 9.23T
06134/01 Engine mount small/G230 RC/Marder, 1pce. 6.76 6.76T
07070/01 Rear shock mount 97, new, 1pce. 16.64 16.64T
07087/02 Lower shock retaining, long 2pcs. 3.06 3.06T
07103/01 Front upright 12.10 12.10T
FG Part Numbers that do not work on the Firehammer
06039 Gear carrier plate, 1pc. 20.67 20.67T
06045 Brake operating shaft each 1 pcs. 7.48 7.48T
06071 Alloy gear plate, 1pce. 11.57 11.57T
06079 Rear driving axle, 1pce. 18.14 18.14T
06080 Rear dogbone, 1pce. 11.25 11.25T
06423 Gear wheel protect.f. 42/44/46/48 t.,set 18.46 18.46T
06427 Plastic gearwheel 46 teeth, 1pce. 12.74 12.74T
06428 Plastic gearwheel 18 teeth,1pce. 7.67 7.67T
06481 Alloy shock absorber 2000 long, 1pce. 28.93 28.93T
07087 Upper shock retaining, 2pcs. 3.06 3.06T
08100 Front lower wishbone 1:5, 1pce. 9.10 9.10T
06010/01 Alloy chassis Zenoah 1 pce. 128.70 128.70T
06028/01 Track rod right/left 1:6, 74mm, 2pcs. 8.06 8.06T
06066/01 Bevel diff. gear A, pluggable, 2pcs. 39.91 39.91T
06069/01 Diff.driving axle, pluggable, 1pce. 18.46 18.46T
06137/01 Bolt f. gear unit 24,5/26,5mm, 3pcs. 5.46 5.46T
08100/01 Front upper wishbone 1:5, 1pce. 9.10 9.10T
I am gonna order them from Germany which is where he gets them. It's gonna cost me an extra $14 but worth it in my opinion. Ship time is supposed to be 8 days too. Not to bad....
