Check out this baja. Owned by Crazy Stu believe it or not. Not sure if he still owns it. Looks sorted ?
Love the pipe.
Upgrades
Engine and clutch
Trevor Simpson 30.5 with Ambush racing ported head, modified sand proof
990 carb
Sko pod pull start with team chase pull start cord
Area rc billet pull start handle
TR Clutch housing
Lauterbacher Adjustable OFFROAD 4-Shoe Billet 54mm Clutch
TR Clutch System GUNMETAL
17T pinion for TR clutches
Team Chase Carb Diaphragm Filter
Replacement LIGHTENED Clutch Bell for Turtle Racing Clutch Systems
Full-Force RC v2 High Flow Fuel Line Kit for HPI Baja 5B/5T
Lunatik Rabid Pipe (ceramic coated)
Rubber Tube for Luna pipe
Drivetrain
Turtle Racing Transmission Cap Slug - GunMetal Spiked
TOOBZ with Tool for HPI Baja 5sc
Hostile Plastic Spur Gear - 57T - For HPI Baja 5B/5T/5SC
Turtle Racing "Quick Diff" Transmission – Silver
Heavy-Duty Drive Gear 20 Tooth for 5b
Heavy-Duty Differential Gear 48 Tooth
Heavy-Duty Idle Gear 30 Tooth
Turtle Racing Billet Differential Case Saver for HPI Baja 5B/5T/5SC
Craftwerks-RC Titanium Layshaft for HPI Baja 5b/5T
Darksoul Gen 4 Dogbones for HPI Baja 5SC
Electronics
Hitec 5755MG (Rhino) Digital Steering Servo
Hitec 7955TG Coreless Digital Throttle Servo
HPI 6v 3000mAh Hump Battery Pack
Killer RC v2 "Killer Bee" Failsafe / Soldered Kill Switch Combo (Optional Buzzer / LED)
Darksoul Billet Servo Saver for HPI Baja 5b/5T
Threshold Servo Saver Spring Support
Fullforce-Rc Full Throttle/Steering Servo Clamp Set for HPI Baja 5b/5T
Darksoul "MeatyMount" Servo Mount/Adapter
Team Twisted RC (Yamadude) Throttle Linkage Set for HPI Baja 5B/5T – BLACK
RECEIVER SWITCH
Killer RC Y-Splitter Cable
Filters and covers
BLUR Quick Release Air Filter System for HPI Baja 5B/5T $65.00
Shockwears - Solid Purple $35.00
Full Force Shock Boots for HPI Baja 5b/5T – Purple
TGN 'Redneck' Dual Stage Pre-Filter for HPI Baja 5B/5T
OW Crankcase/Flywheel Cover – Black
Pull Start Cover - Black
Baja Outerwear Airfilter Cover – Black
Wheels and tyres
Hostile MX Knobby Rear Tire Set for 5b (HARD Compound)
Hostile MX Knobby Rear Tire Set for 5b (EXTRA HARD Compound)
Hostile REAR 5b Zero Growth Molded Foam Inserts – Soft x 4
Pro-line Desperado Rims 5B rear x 4
Shims and Screws
Team Fasteddy Steering Post Shim Kit for HPI Baja 5B/5T
TeamFastEddy Complete Professional Series Bearing Upgrade Kit for HPI Baja 5B/5T
Team Fast Eddy Pro shim kit
Team Fasteddy Hinge Pin Shims - Thick 1mm
Team Fast Eddy Hinge pin shims - thin .2mm
Team Fast Eddy Hinge pin shims - medium .5mm
Tony's screw kit
Chassis
Team Chase High Strength Plastic Roll Cage for HPI Baja 5T/5SC – Black
RPM Front Arms – White
RPM Rear Arms - White
Hostile Heim End Conversion Kit for Hostile Hubs
Hostile Adjustable Rear Hub for HPI Baja 5b/5T/5SC
Turtle Tower/Mount 5T Combo SILVER
Turtle HD Shock Mount SILVER V2
Aluminum Main Chassis – Silver
Team Chase Axle Boot Protectors for HPI Baja 5b/5T
Turtle Billet HD Top Plate for 5T - Silver
Fullforce Rc Aluminum Front Lower Chassis Brace for 5B/5T/5SC
Rear Shock Towers from Team Chase
GBE Billet Polished HD Rear Engine Mount for HPI Baja 5B/5T/5SC
Hostile Spur Pins - Blue
Turtle Billet HD Tranny – Silver
Miscellaneous
Kraken HPI bullet fueler
Killer RC "Killer Cables" Suspension Limiting Cables – Green
Team FastEddy Steel Work Stand for HPI Baja 5B/5T – Gray
AXLE BOOT 25x47mm
Kraken RC V2 Team Chase Roll Cage Adapter for the Bullet Fueler – Black
Turtle Racing One Piece Brake Mount - Silver
