Crucial Kraken Vekta.5
Progress. Pulled engine/trans cause I forgot to lube up gears. 14 screws to get her out. Madgreek was right, it's not something you want to keep doing?
Kraken billet heim joints and spindles
New Vertigo bellcrank brace cause I had to cut the old one off due to breaking a hex ball end inside the grub screws when i first got the truck?
Radio tray in
Servos bolted down with a closer look
RC Max shock tower and Kraken antisway bar fitted.
Pipe bracket not lining up with mounting tab.
Had to cut away the left stock spindle because the upper capture nut kept spinning. Whoever put this truck together the 1st time used red loctite on every bolt.
Quick overview with the pipe just sitting up there. Got to put my Sanwa receiver in the rx box and clean up the wiring. And tires?
Amazing grace
..how sweet the sound :ROFLMAO: .....i once bought an immaclute td dnx401 truggy roller and sum twwwaaat had used red locktight on every feking thing ?‍♂️:mad::rolleyes::cry:...took me feking ages toget the tiny 2/3mm hex bolts out the damned thing ?
what should of been a 30-40min job ended up taking around 3 feking hrs?????:rolleyes::ROFLMAO:
rounded out like 70% of the hexs on it ffs?
