- 22,962
I just got off another week of plowing. It snows and blows, then you have to deal with the drifts. Nice part is I got 19.5 hrs of overtime, and its gonna be close to 60* tomorrow.
That's not the only damage on it btw. I noticed some scratching ok the bore. Most of it is can't feel with my finger nail but on the exhuast side i believe i can,and on the top on the bore. Again, let me reiterate. Im not stuck in the past, I've moved on , im just showing what i found ?
bit boring init.....?....c what i did there?That's not the only damage on it btw. I noticed some scratching ok the bore. Most of it is can't feel with my finger nail but on the exhuast side i believe i can,and on the top on the bore. Again, let me reiterate. Im not stuck in the past, I've moved on , im just showing what i found ?
It is? Didn't know that. For a cylinder that has less than a half hour ?That's more or less normal looking for a cylinder that's been run. Sucks the bottom end didnt work out. Oh well...
Ever changing but all the stuff to complete the motor, TR fr/rr top plates, piston stop, exhuast spring tool, shock n diff oil, rpm front arms, flm dog bones, ffrc shock tower, hex hub pins, vertigo 19t hex pinion, screw kit, TR quick diff, aluminum brake mount, shock orings, spur gear carrier.What's your list?
Drano, normally use easy off oven cleaner but was out and being lazy. Sidenote: drano sucks, not strong enough and takes ages to strip.Nice. What did you use strip? I use ZEP industrial cleaner
Yep, works fast, just gotta be careful and watch it all the time.Easy off works great to. I use that for stripping the chrome off headlight buckets when I build them
Thanx ?ni?ce!
