Bryan K.
Hey guys, so this isn't really a huge issue, but it's annoying and since I have time, might as well figure it out. I bought a used original HPI Baja last summer and it needed some TLC. Runs great now except for the issue I have listed in the title. No matter how low I set the idle, I cannot get the clutch to disengage. When I do eventually get the idle low enough to stop the clutch from engaging, the motor dies after a few seconds. Is there something wrong with my clutch? If the spring is broken, the clutch would fail to engage correct? I was thinking maybe it had a very low RPM spring and a higher RPM clutch spring would fix this issue? I've played around with carb settings to try to bring down the idle, but that doesn't work either. I've just been living with it, because it only rolls away slowly on flat ground. If I lightly tap the brakes or the thing sits on a slight incline, it won't move. Any ideas? It's a purple chassis, so I guess it's an older Baja. The thing has DDM stickers all over the motor, has an MSD ignition wire and the piston doesn't look like the stock CY. I know the housings at least are CY. The thing blows my DBXL CY30cc out of the water, so I feel like the motor might be upgraded.
