Thank you good sir! If I get the extensions I can run rear correct?You need 2 fronts.
The rears on Baja are just narrower wheels I thinkThank you good sir! If I get the extensions I can run rear correct?
Buy madmax giant grip from DDM?? stronger ??Was debating on buying these but was unsure if they'd fit? Do I need front and rear or two fronts or what fits the losi? Any help Is appreciated, I'm at home today and don't have my calipers or I'd just measure everything and see
Rear tires are wider than losi tires ??
