SELWA
I bought a roller and saw a lot of play in these areas. The front and rear metal braces. (Orange or purple aluminum pcs)Sure they part is only $5 but still it's metal on metal (aluminum). You can pick up FG# 1097/1. These are 6 plastic collars for $4. Simply drill out the hole a bit bigger, cut the depth of the collars a bit. Squeeze into the larger holes and you have a snug fit. Once they are worn just replace.
