The 🐙 krakenbone beater 🤣
Your rear shocks are too hard, I'd bet all that arse bouncing put quite the shock load on the trans, keen to see what ? the bed. Looked good proper fun though, I am rather jealous of you guys with close tracks like that. Closest to me would be Bob's track amd that's at least 3 hr drive.
All the cars bouce on the rear straight ??‍♂️ shocks have 0 preload and only 25wt oil? pretty light ?? need to strip down ??
That was a good video Dougy. You think the pin may have broke on the lay shaft?
Still think it gears coz it has engagement on half (180) but not the other?‍♂️
I don't think it's the gears, I think it's either a pin or maybe the trans Case feked itself and the meshing is too tight. Those stock gears are tough
In the vid I go through the same bends then you can hear my start reving like fek? then I get rear ended ?? thats where the ? went down?‍♂️ .....give me some time to wrench and we will see??
Keen to see the pix ?
