Seasonal rebuild for my Baja 5b!
Yeah and the fecking bums with the coil haven't even given it to usps ?‍♂️
If it makes you feel better, it took 8 business days for a priority package fro. Ohio to get to my house. Should have taken 2 tops. Expected delivery date on the package was the 5th. Showed up this afternoon. I have zero faith in the postal system anymore.
got the ddm stuff today (mainly misc hardware, engine shroud and clutch housing). the coil still hasnt moved and the dude responded and said they shipped it out. either hes lying or usps tracking is wrong. really should have just bought it from ddm as im impatient but its too late now :rolleyes: so i can assemble most of the engine just not the coil. i will mock it up but i want to do the final engine assemble on cam like last year ( will make the vids way shorter this time).
I ordered from ddm a month ago, it said "usps" waiting for item arrival for 3 days before it said shipped even though they had it.
2 hole all around. In the rear I also have the ddm stiffer springs , I only use the longer ones includes, and use the stock short springs with them (using all 4 stiff springs are way too stiff and bouncy for my taste )
pls could you measure the spring wire diameter of DDM stiff springs? recently i asked a small local workshop to wind some harder springs for me. they are from 2,5mm wire and i’ve calculated the # of active turns.
just would like to compare with the ddm ones. ?
Very interesting. Are they able to do most sizes?
Mockup pics: goddamn this thing is sexy ?
View attachment 68106View attachment 68107View attachment 68108View attachment 68109View attachment 68110View attachment 68111View attachment 68112View attachment 68113
Something I learned, this 34 is quite larger then the 30.5 . The head looks huge compared to the baby 30.5 ?
And those fugly orange fuel lines will be replaced with all black lines Soon. Hurry up Usps ??
PM me your adress and I'll send you a couple feet of fuel line to try out, if you like.
