Adjustable clutch ? anyone make one
Then the alx is what your looking for
Ya I looked at that one , I can change the springs on mine just as fast , The kart clutches we used to use had allen screw to adjust the engagement RPM , not finding that type , no big deal I have a quick change clutch setup on the motor now.
From what I seen MOD is probably the best on market right now. Elcon comes in second or first in some on-road circles.
I might have to take back what I said. Just seen Dougs post!
Just checked out the ALX kit. It says tunable but correct me anyone who has one, you still need to remove the bell?
Also does anyone run a 54mm clutch with steel pads? How's the wear?
I see everyone running clutches with the pads so assumed the steel wasn't worth the $$$. If this is the case and you have to adjust via removing the bell, I think a composite pad design like the MOD or Elcon would be best for wear resistance and longevity. MOD is the option I plan on going with anyways. That ALX kit is $250!
Ok then the decision is between a larger surface area or multiple composite pads. Anyone have something to say about steel vs composite pads?
