hey all im just after getting my new head kit on the zen engine went for the same 26cc kit,piston cylinder,ring,gasket etc, i watched a video on an engine rebuild just to remind me of the whole show,so i rebuilt it but cannot start,i striped it down and everything is grand but cannot start the thing,
the one thing i can say is that the engine is flooding with a hell of a lot of petrol just after a few cranks,yesterday the exhaust was completely full of fuel...
strange,i cleaned it down and dried it all up and nope just don't wanna fire up,and yes plenty of spark with new plug....
all genuine parts, and iv done a few rebuilds......
help any??
Did you get it straightened out?
...If not, I was thinking maybe the gap between the coil and the flywheel was set too high? (I use a business card to set the distance, approx .015" or .381mm) The reason I was thinking this is because, you can have good spark when the plug is out of the head, but when the plug is In the head, the compression can "Blow-out" the spark. It is not as common on our small 2-strokes, but it happens alot on bigger motors, but compression and pipes whether tuned or not, have a big affect on how a 2-stroke operates.
This a true story that I would happily swear my life on...
I know this sounds a little strange... But I was playing around with a flooded (snowmobile) engine... The motor was flooded like crazy, (At the time I didn't know it was flooded) I pulled the pull rope, time and time again, but it wouldn't fire... So I removed the plugs and thought I would check for spark ...I grounded the plugs on the heads. (As anyone would do to check for spark) Then I yanked the pull rope again.
On the first pull, it shot gas/petrol about 3 feet/1 meter into the air. On the second pull, the engine Fired!!!!!! It STARTED! The plugs were lying on the heads!
...I could see the spark coming from the spark plugs and igniting the fuel while the "spray" of fuel was being sucked backed down into the combustion chamber!!! (Surprising to me at the time, there was not a big flame coming from the spark plug holes, just a line of fire travailing into the motor) The engine revved uncontrollably for about 10-15 seconds then I hit the kill switch.
So after that, I realized carb tuning is not that important to get the engine to run, but it is important to get it to run properly.
I would drain the fuel tank and drain the fuel lines. Then drop a few drops of fuel (about a thimbleful) into the spark plug hole and give the pull rope a tug. If it fires, then you know it is carb problems. If it does NOT fire, start checking ignition or compression...
Let us know,
Trip..
Just my 2 cents, but it may only be worth half of what I said...
