Ridgid stand add on.
How do you like the Ridgid stand for the truck, is it wobbly at all?
Digging the crackle paint btw ?
Thanks about the paint, not to wobbly I bolted the plate instead of the pin and I stuck weather stripping on plate and it holds chassis from sliding really well.
Side question is how do you like the duratrax tires? Do you know if they fit the front also without problems? Thanks
But have you added the spin feature??
No but kinda curious, got pics
I don't know yet never seen the dirt yet. They don't seem bad and they fit nice but when the snow melts I'll find out .
Sorry I don't know if they fit the front.
Gordo i went to home depot. bought a 5/8" steel rod and four 5/8" washers. I cut the upright post 5" down from the bottom of the cross bar.
Then i cut the 5/8 rod to 15.5" and inserted it onto the top pipe. Welded the washer to the pipe
Then the rod to the washer. Then i welded the second washer to the bottom pipe while the rod was inside to keep everything aligned
The old spin effect would be nice. Nice job, I like it.
Got It. I may just try them. I was planning on the madmax mx but after putting them on my 5ive be I think the lockup’s might be better for the 5sc for the terrain I drive on.
