Anyone Do Their Own Porting?
We 4 wheeled for years, hydro lock kinda happened every now and then. Worst was my brothers comanche, 2 bent rods and a section of the head gasket was literally pushed out between the head and block. That was a long day.....
did a 28.5cc for a friend today. no over the top port work. just added some timings on exh and inlet.
i've cut my CY26 (25,4cc) to 173deg on exh and 155deg on inlet. but did not try it yet. TP's were just cut to flow... similarly to yours
how is your port durations that you wanna try? ... if i may ask
i do not want to open a new thread for this:
i'm about to port one more rovan g320rc for the +2mm stroker crank (for a non-reed case). when i calculate the blow down, i have 2 transfer ports. the one next to the exhaust port supposedly the main transfer, the other is the auxiliary. on a downstroke, the main opens about 3 deg LATER than the auxiliary (closer to the intake port).
which transfer port i should use to define the blowdown?
thanks in advance!
