It's not rocket science really. I'm not good at explaining it, but ok at doing it.You gained a bunch more respect for that. So far over my head. Keep doing what you do Mr. Donato!!
thanks Sean!Whichever opens first. But it's used to get the old charge moving out of the cylinder faster. The main transfer event is both of them open.
Found on cheap cylinders it best to start off with a diamond burr and "trace" your outline to grind the plating away. Seems to help with chipping. Large chamfers seem to help with plating retention as well.we will run this motor on Sunday in a club race. will make a video to share.
the quality of the marine zenoah barrels outshines these cheap versions. even with a brand new dremmel cutter, the chrome flake away as on a rcmk or zenoah, you really have to work the cutter.
well for one thing he should be covering the bearings even if you clean after its best not to get metal shavings in them at all at least thats my thoughtI was just watching that vid!.... Well isn't a +2mm stroker with machined head considered a big bore?.... I was thinking the same about have a local machine shop do a few for me but now that I'm learning these cases need more room to accommodate the stroker cranks this whole endeavor seems kind of useless. If all the major performance mods need to be done with heavy machinery then I guess I'll be stuck buying OBR or ESP gear.
For some reason I feel like this isn't the proper way. lol
damn that track is sick I wish they had a track around my location even a poopy one the best we got is the end of a street and the dustiest freeway interchange area which I will never go on again unless it rains cause my bearings can't take that kind of a beatinghi all.
we had some really nice racing yesterday. the 38cc was way better than before. here is a short video of it. these are all 4x4
the bakkie in the 3rd spot from start running the motor i did
some of the baja's that also run
Did you read the entire conversation or just the parts that stuck out? We already covered that you don't shave the crank down, and clearance the case halves.well for one thing he should be covering the bearings even if you clean after its best not to get metal shavings in them at all at least thats my thought
and shaving the crank takes away balance correct? I wouldn't do that either
