KevTrem
Afternoon all.
I finally killed my 57 tooth hostile spur the other day (after 15months use) due to pinion bolt coming loose.
So need to replace it, but should I stick with my 17/57 set up or go for an 18/56??
The reason I ask is I have been known to snap the drive pins with the 29cc and the acceleration to top speed is very quick, clutch wear is minimal.
The hostile spur is only £10, same for 56 or 57tooth, the pinion is £15 for 18tooth so cost is negatable. It generally runs on open fields with the occasional gravel carpark bash.
What would you do?
Thanks in advance
What would you do?
Thanks in advance
