shouldnt the horn be at 90 degrees off servoServo horn isn't properly centered on the servo. And you may have to take tour travel limit past 100.
there is no adjustment on the rod that connects horn to steering, so if i move horn its throwing off steering, i had this same problem with last servoshouldnt the horn be at 90 degrees off servo
yes, it looks like your servo wasnt centered when you put on the hornshouldnt the horn be at 90 degrees off servo
No I mean like the the trimyes, it looks like your servo wasnt centered when you put on the horn
Yep and make sure everything is set to center on your radioAlso helps to turn the radio system on so the servo can center itself before setting the horn on it
