Finally got one!
I pull the pull start when the manifold was off and had gas coming out of that hole in the picture. So not sure If it's normal or not..
It poured out good amount. Definitely not couple of drops. Like I said, this was when the manifold was off and I pull the handle and fuel came out.
Finally picked up one from ddm. I got the package with the 320 motor and the kraken servos. I already took most of it apart and reassembled it back just to make sure everything is good. It was put together pretty good as it is. All the screws had good amount of locktite on them.
Going to order some more parts to give it a little more bling.
If you want a trouble free transmission you need to update to the VEKTA.5 CVD Rear Driveshaft System for KV5/KV5LSE/KV5TT - KV6127. I would not run it without a kill switch.​
Sincerely,​
William E. Burrows Jr.​
Sincerely,​
Hes way beyond that my friend
🤷🏻‍♂️ hes got some catching up to do on your thread😂
So rcmax messaged me he told me the engine is flooded that's why I had fuel coming out of the little hole. Honestly with the zenoah engines I had I barely flooded the motor maybe 2-3 times and they wouldn't even start unless the fuel was out.
Not sure how the big bores operate but how is the engine running when is flooded??
I did put in order for rebuilt kit on the carb and got the slipper components just to be on the safe side.
No is not plugged. I have been running the losi 5b cap. Works great as always did since tne car was new with the 32cc. Never touched it with the big bore and ran great through 4 tanks until now.
I believe If it is plugged it will be other way around not feeding fuel.
The car sits in the garage so not much heat.
It's pretty much a one way in these things, let's air in not so much out. I still doubt that it's causing the carb to flood. It takes a decent bit of pressure to lift the needle off its seat. Not that it couldn't, just I think it's unlikely.
Ok stupid question... is your filter clean, also is your outerwear clear? My friends 5t was running like 💩 yesterday no matter what tune I put in it. Took off the outerwear which was clogged and it ran amazing. Like I said... stupid question, just wanna rule that out for sure
