- Crafers South Australia
My reed was was lose and carb.
Tightend them and I was sorted what carb is on your motor
990 modded carb. I checked the screws and they are very tight.My reed was was lose and carb.
ill buy it if ur seriousFor sale guys. $1500 obo. Runs great!!!!!
Absolutely not. LolI think you would have bent the linkage first.
1500 obo??Are you serious?
Don't you have an 1107 or anything laying around, or bolted on another engine?I did pull the plug it looked fine little wet but fine. I changed it out with new one also.
Might have to buy a regular 990 from ddm and see if it works. The rooster tail is very expensive.
The plug isn't the issue, and I doubt it's an air leak. Those carbs are made for heavy fuel delivery. You should be able to lean it out quite a bit, or the pop pressure is screwed up. Just for shits and giggles. I'd toss one of your other carbs on first and see what it does. Id personally skip the wj. It's just simply not needed for this application imo. Im kinda surprised Mike didn't say to lean out the low screw a bit as well. Any ways, the exterior of your carb looks like a carb lol. Can't see anything with the covers mate!
Thats the pulse hole the pumps fuel
