ChromaticWolf
I have mechanical disk brakes installed, what are these extended ones good for? will they work with my brakes?
View attachment 76670View attachment 76671
What's the difference between the extended ones and the original?Those will work but I suggest getting the dgi clipless version.
These are the extended ones? don't they make the front wheels wider than the rear? do you recommend them over the original?Don’t know if they will, it depends on your calliper spacing. I have these ones made by Fruitbat on here.
I have hydraulic brakes though and they could be quite different.
I’d get front and rear extenders personally. I think front only would look weird. The ones you posted are an old design also. Get clipless extenders. PM Fruitbat.What's the difference between the extended ones and the original?
