Wow, underwhelming!
What are the numbers on a stocker running the same pipe? Surprised the way the HP curve charts out, didn’t expect such a steep fall off on the plotting?
Disappointing I knowim not saying its you or simon. im saying his shed-build looking dyno is saying some false info
The steep drop is me letting the throttle gothat does seem really low doug, plus the steep fall off in power and torque from 12.5k seems strange like bizzer said above,
I wasn't far off the markI've said it will push 4.5 -5.5hpsimons say 5-6hp
hope you post up simons results when ya get em dougSo he tested a zen 32 with his pipe 4.5 hp . 34 with his pipe 4.81hp
The steep drop is me letting the throttle goSimon will mail me with the results so we can see
also he was saying a twin motor pushes 9hp
This what I said from the beginning
I wasn't far off the mark![]()
i think this is his older one out of his beater baja (that was originally in his kraken)hope you post up simons results when ya get em doug,
so was the power and torque dropping when ya let off the throttle doug ?
what i mean is you didnt hold it wide open above the 13k or so,
aint this a fresh engine as well, not much fuel through it i mean,
if so it be interesting to see a repeat dyno session after another say 5 or 10 tanks through it, see if theres an improvement in power and torque,
i'm interested doug![]()
ah right Z, i thought it was the new onei think this is his older one out of his beater baja (that was originally in his kraken)
Thanks Sean, it was just my assumption a two stroker would hold the power in the higher revs better. Guess not, learn something new every day!2 strokes are peaky and fall off the power fast, a reed should have more torque then a piston port, but will fall off fast as well. I'd honestly say, it's an accurate representation of the power difference in modified engines.
