Tore Losi DBXL-E v2 body panel
TimS
Hi all
My Losi took its first tumble which resulted in a small (1/2") vertical split in the front panel just above the shock.
Any recommendations as to how I can repair it to stop it from getting worse? My initial idea is to just put some making tape on the inside and cover it in super glue but any advice would be appreciated.
Subject to your comments, I'll do the other side too as it looks like a bit of a weak spot.
Cheers.
I like that!
I'm assuming you used lexan scissors but did you use some sort of template to get both sides so even?
Not sure as it is not my car. Someone on Facebook page did it. This is a common problem on these models with the shock tower punching through the body. Myself I apply shoo goo and drywall tape to all my cars before I run them.
Definitely regret not going the Shoo goo route in the first instance myself.
Any chance you could let me have the FB link for that pic please as I can't seem to find it.
Thanks
You can remove the upper plastic body part that sits right under the nose and screws to the shock tower. That will take the pressure off the nose, give it more flex, and allow the body to easyily slip into the mounts and put the clips in
This is an old post, but it is new to me since I am new to the DBXL-E. I want to protect my body in the same way with drywall tape and shoe goo.
Did you do all the panels or certain panels subject to direct damage?
I always do all the panels. Actually pretty easy compared to losi 5T. 😆
Thanks...will do. I have owned a Losi DB Pro for years and did all the panels on it. I will follow your example here. Thanks!
BTW...did you add washers behind behind the outside panel screws for the body?
