Thanks,could be a few different things mate,
post a pic or two then we can see if anything stands out,
is the baja completely stock? or do ya have aftermarket a arms, dogbones or i-rc big bore shocks fitted etc,
plus are you using the 22mm or 25mm boots,
edit; i have had boots rub on the baja before , but was barely rubbing and didnt destroy the boots,
well it did, but took a fair while,
might be that yours are just rubbing on full extension/droop when cornering hard or sommat, limiting cables/straps would cure that
Here some picscould be a few different things mate,
the suspension ball has no offset... it is a visual effect due to the angle of the photo.look at the pic of the shock bottom mate, the one on the right,
looks like you have offset balls (for want of a better word ),
if they are offset, then just remove the lower shock bolt, pull the shock bottom up and out,
rotate 180 degrees and refit, it looks in the pic that that will give you a few mm of clearance,
ah right mate, yours are very close, i don't recall any of mine being that close even with i-rc big bore shocks,the suspension ball has no offset... it is a visual effect due to the angle of the photo.
On my setup I use 1° while the standard setup is 4°.How much tow in do you have on those tires? Maybe too excessive?
then theres defo sommat wrong mate,On my setup I use 1° while the standard setup is 4°.
If I go for 4° toe angle the issue is even worse.
Thank you mate! You saved me.then theres defo sommat wrong mate,
can you post a pic of how you have your rear shocks mounted please?,
i think i may know what your problem is,
have you mounted the top of the rear shocks to the front side of the shock mount?
if you have, then easy fix, there supposed to mount to the rear of the shock mount,
hopefully thats the issue, easy mistake to make and we all make mistakes from time to time,
you're welcome mateThank you mate! You saved me.
I don't know how I made such a stupid mistake.
