I emphasized wd-40 because it doesn't leave a burned residue, think back to the nitro days when the oil would bake onto the header.
Don't forget about the dry silicon spray.... keeps the dust bunnies and water away.....The faster you get water off the rig the better off you'll be in the long run. Certain areas of the rig that doesn't have paint, anodizing, chrome will flash rust so using wd-40 not only chases the water away it also creates a barrier for dust and water for the next time. I also read at one point that wd-40 doesn't harm any of the plastics used in rc and it also helps to bring life back into dull plastics.
As for bearings they will seize up almost overnite depending on how wet they are as well as if there's no grease left.
Always do a "pre" trip inspection of the rig before you take it out as you'll be surprised when you catch something that could end your day early. When you come home clean it up and check it over again so what you need or what needs tending to will be in your head and you won't be rushing when you want to go run it again.
Also is the new pipe you bought chrome or raw?
I have a construction job and many simple cleaners and lubricants are in abundance. That's why I ask.Don't forget about the dry silicon spray.... keeps the dust bunnies and water away.....
Guess I should expand on that. Wd40 is great, but over time it will leave a residue if your maintenance is sloppy and it dries out pretty quick. I use it on my pipe too, and sometimes on plastic, but generally speaking the entire rig gets sprayed down with a dry silicon spray. It repels water, and dirt doesn't stuck to it, and since it's a dry make up, you don't have to worry about it drying out like wd40 does. I'm not brand specific, the last can was a a wd40 brand and I'm currently using mukoff. Pipe still gets regular wd-40.
i cannot describe how much i hate thatthink back to the nitro days when the oil would bake onto the header.
