Carb Settings Zenoah 32cc
Urtrippin
New Member
Hey guys just curious, for racing what carb settings do you guys run from closed to open for the zenoah 32cc engine?
Start off with the factory settings and adjust as needed. All depends on your setup.
1107 is the stock carb that comes on that engine.
doesn't make too much difference anyway. these aren't nitro engines, tuning window's pretty big and flat
um you should have at least half a turn usually more in tuning window in my experience in my gas cars
Idk about a half a turn thats quite a lot. An 1/8 of a turn is normally the base for tweaking a carb. Even then it can be smaller adjustments for fine tuning. Typically the engine dictates how it wants tuned. I have engines here that need it once every now and then, amd then others that need tuned during the daily temp swings.
