DBXL 2.0 Drive shaft boots?
tizdaz
Sunny Northwest!
Hi guys
today one of my shaft boots got completely destroyed (piece of wood got cought in the shaft, rest is history as they say!!)
anyway do the 5T shaft boots fit the dbxl 2.0? As all i can seem to find ones that are labelled for the dbxl 2.0 is in china! :( ?
any info for which ones fit much appreciated as i want to try find some that are in stock in the UK that will fit :)
Cheers!
The factory ones were the best fitting on the 1.0 if memory serves, and I booted everything I could, including the center shafts. Wouldn't hurt to grab a set for the 5ive and see how they fit.
oki doke cheers buddy!
i cant fit them to center diff shaft outputs as they are too close to the brake calipers housing so would rub:
I'd have to go back and look at my old build thread, I think the brake side was the only one I didn't run booted. Gets in the waynof the brake disk floating.
yeh thought so, on the 2.0 there is a disc on both sides so fitting boots there would rub, but all others as you say should fit so will have a go in the week :)
