Crucial Kraken Vesla
@crucialRC
The linkage setup is perfect for a Baja. It is thick and doesn't bend much. I have the so called upgraded one from Detroit and still bends. The kraken one is also much cheaper at $20.
Started getting her ready in-between races. Decided on the the 55 supreme for this build. Mocking up the engine in the buggy so I can see how my sx5 cage will fit with the big trc pipe. Now gotta tear her down and and send some parts to Travis at Bateman Coatings to get that signature color on them. The name for this build will be Purple Haze.
20230331_190926.webp20230331_172415.webp20230331_172849.webpreceived_776946683567061.webp20230410_172347.webp20230410_203332.webp20230413_150832.webp
Sweating James Mcavoy GIF
Update time. Rear end. Able to get some parts on it today. I mocked up the engine and pipe completely so I can make sure the sx5 cage fits without issues and with only minor cage trimming it fits like a charm. Also installed the vekta quick release parts on it, thanks to @John Parks. I'm using the kraken billet upgrade trans case and gear plate. Taylor Blackbone gear layshaft and clip-less hinge pins. EVERYTHING fit with no issues guys. I did notice there wasnt much diff fluid from the factory. I added 1M fluid to it. Also wasnt much grease on the trans gears. Fixed that with some MCD diff grease. The rear arms needed some hinge pin shims and the right engine brace needed to be trimmed to allow the larger 62mm Taylor Blackbone bell.
Not much diff fluid
20230429_161733.jpg20230429_163522.jpg20230429_164542.jpg20230429_165412.jpg20230429_165421.jpg20230429_172728.jpg20230429_174234.jpg
Had to add (5).5mm shims
JS shock stops fitted
Stiffer Kraken rear springs added
View attachment 87033View attachment 87034View attachment 87035View attachment 87036View attachment 87037View attachment 87038View attachment 87039View attachment 87040View attachment 87041View attachment 87042View attachment 87043View attachment 87044View attachment 87045View attachment 87046View attachment 87047
NIce work, you found the same things as I did. Their tolerances are so far out.
So the front end and electronics are done. That battery box is a beast, crazy small. I talked with Dean at BoneHead-RC and Mike Taylor about making some CF shock towers and hinge pin braces and Dean got them made up quick. First set on the way to the US. 20230501_160849.jpg20230501_161257.jpg20230501_161303.jpg20230501_161306.jpg20230501_161310.jpg20230506_114835.jpg20230506_114807.jpg20230506_114818.jpgScreenshot_20230505_200532_Chrome.jpg
Is the angle of the shocks able to be fixed at all?
I don't think so. The shear length and size of the shocks will make it difficult. The rear looks like it would be possible but the front looks real iffy. Dean also doesn't have a vesla in his shop at the moment so trying and fitting is impossible for him right now. Maybe in the future tho. 20230506_115719.webp20230506_115723.webp20230506_115731.webp20230506_115736.webp
