GoneRogue
Active Member
Hey Guys,
Just engine swapped my baja as my last engine went capoot. After installing the new one I went to see if it started and it would start but it would instantly stall, no throttle or anything applied just stalls after 1 second. I have had this happen to me before and it was an air leak from the exhaust port but I have made sure everything is tight and I don't see anywhere there could be an air leak. I have also tried replacing the plug and that didn't help, the other one also didn't look spoiled either. Maybe I need a new carb?! Or my fuel lines are not working as they should?. Not sure what else to look for, or anyway I can find an air leak if there is one. Any advice would be much appreciated.
