DBXL 2.0 DBXL E 2.0 Steering
Eric H
New Member
I got my new DBXL Lee 2.0 out for the first run after mounting Krayton 8S wheel tire/wheels. I was running in some dirt and very easy terrain and broke both turn buckles within 10 minutes. I replaced the turnbuckles and added the servo saver and aluminum top plate along with the other aluminum chassis braces. It looks good, but the servo will only fully turn the wheels to the right, and only partially to the left, even though I can move them freely by hand. Any ideas?
Will it turn full lock with the wheels off the ground? You may have not centered your steering links
Yes, and Horizonhobby tech told me to reset the transmitter and bind it again, and it did turn all the way to the left and right but now I’ve lost all connection between the receiver and transmitter and waiting to hear on what to do with that.
hmm, sounds like a dodgy RX, which may be the reason why your turnbuckles were damaged in first place, a faulty rx can cause all sorts of issues, one of which is the EPA's, so your servo travel may have gone too far damaging the turnbuckles!
They are sending me a new receiver since now it will no longer bind.
