Would it drop straight in?And would it droostraight DDM, they sell esp stuff exclusively.
Are they UK?
you could do it this way fella, build yer own engine,
get a stock g320,
https://www.rcmodelz.co.uk/engines/...320rc-31-8cc-engine-stock-clutch-housing.html
then either keep it as a 32cc but esp and fit this,
https://www.rcmodelz.co.uk/engines/...38mm-31-8cc-esp-race-ported-stock-stroke.html
or upgrade to 34cc with this full esp conversion kit,
https://www.rcmodelz.co.uk/engines/...der-modified-crankcase-2mm-stroker-crank.html
edit; rcmodelz in the uk, they're in stock but only have 1 of each left,
Is the last link have the engine included?you could do it this way fella, build yer own engine,
get a stock g320,
If I get the g320 and the upgrade to the 34 , will I need to buy anything else?Is the last link have the engine included?
yeh there isnt a massive amount of esp stuff over here ryan, but rcmodelz tend to keep small amounts in stock@spents I stand corrected, I thought only ddm sold esp stuff. That's great for you uk guys.
nah mate the last link is the upgrade kit, modified cases for the +2mm crank to clear,Is the last link have the engine included?
right fella, if you buy a stock zenoah g320 and then the esp 34 conversion kit in the 3rd link, you then can swap over the coil, fan case, heat shroud, clutch case, coil, carb and carb insulator etc to the conversion kit,and build that engine up as an esp 34,I like this advice , confused tho.if I follow your sound advice to the letter, what am I getting/buying?
Thanks gotcharight fella, if you buy a stock zenoah g320 and then the esp 34 conversion kit in the 3rd link, you then can swap over the coil, fan case, heat shroud, clutch case, coil, carb and carb insulator etc to the conversion kit,and build that engine up as an esp 34,
the esp conversion kit comes with modified crank cases so the +2mm crank that comes with that kit will fit without catching on the inside of the crank case,
to convert a stock g320 crank case to use that crank a small amount needs to be removed from the inside of the case so the +2mm larger crank will clear the case,
then you will have an esp 34 up and running and most of a stock g320 left over, which you can then add new parts you removed as and when you can afford them to build back up the stock g320 and have that as a back up engine,
or you could just buy the conversion kit and then buy all the parts needed to complete the engine, but doing it that way will cost you probably about the same as or at least half of a new g320,so makes sense financially to just buy a stock g320 to start with and then you have most of a spare engine for future use as and when you need or want to,
This is the best,most specific advice ever and is greatly appreciatedright fella, if you buy a stock zenoah g320 and then the esp 34 conversion kit in the 3rd link, you then can swap over the coil, fan case, heat shroud, clutch case, coil, carb and carb insulator etc to the conversion kit,and build that engine up as an esp 34,
Hi spents,just ordered link 1 and 3 , may need your brilliant brains once it arrives but am looking forward to having my rr5 going fast as she shouldyou could do it this way fella, build yer own engine,
get a stock g320,
