tizdaz
Hi Guys,
As some of you know, I purchased an ESP engine ported 340 engine in August last year, ive probably used my RC around 3 times in that time due to my work etc, the times ive used it its been great, Today I decided to take it out, started after a couple of pulls with plenty of compression as usual, but after a minute or 2 the engine just stopped dead while running around 1/2 throttle, when I tried to pull the pull start to get it running again, the pull start seems jammed solid then it loosened up allowing me to pull, but it has lost a lot of compression to what there was before. When I pull the pull start now there is little to no resistance!? There are no leaks anywhere around head, spark plug is tight etc, but when I try to start it there’s nothing and like I say, compression is very minimum to what it was so I have a nasty feeling its something internal!?
Ive not yet taken the engine apart as Ive sent a mail to DDM to see what they say. But it defo seems as its something internal, either worn ring or something worse!?
Any ideas?
Any ideas?
