It looks like the top tuning conversion kit. I made my own battery trays. Got a 3D printer?Looks amazing. I cannot imagine the plastic diff cases and bulkheads lasting with that amount of power and RPM, lol.
Do you know if those battery trays are available without the motor/esc as well?
I am pretty sure that is the top tuning kit on the mgm site. Everything looks identical to mine, including every little hole in the battery tray for adjustments.Actually, I do!
And I thought it was this kit: https://www.mgm-controllers.com/esc-motor-combo-for-losi-5ive-t-conversion-kit
Good point about the balance. Let me know if you need the files or need a set printed and shipped.I need to set my batts up like that, one on each side for the balance. I used the Stupid RC kit for mine.
I used PETG, 7 walls, 40% infill. You could probably go with fewer walls and less infill if using a better filament like PC or Nylon.What did you print them with? I have some PLA and PLA+ but can't get ABS to print worth beans. If the file is STL I can try it out.
Printers with built-in enclosures are a game changer for ABS/ASA, nylon, and PC. Especially if they have an active heated chamber.I don't have any PETG on hand but have had success with it in the past. I use a Neptune 2s or 4. Also have a small resin printer.
I tried all of the things that Seandonato73 listed to get ABS to work right. Just no luck with it. I have had a lil success with small abs things, right in the very center of the build plate size stuff. I think if I get another printer the build plate heating will be what I look at most, seems to be the big issue with ABS.
