Help me understand Vekta.5 transmission gearing please.
Tacoma, WA
Kraken Vekta.5 with ESP 34cc engine and full Vertigo transmission.
With stock tires I am currently running the 19t/22t configuration. I am installing the Maxxis Trepadore tires and need to lower my gearing to match the larger size tires. I am assuming using the 17t as the pinion and the 24r as the intermediate is the lowest gearing I can achieve with the Vertigo gears? I am hoping this is a good place to start and isn't too low.
I am assuming 17p/24 is the lowest, 24t/17 is the highest, and the 19/22 and the 18/23 are in_between?
19/22 = 1.16 ratio
17/24 = 1.41 ratio
19.45 percent difference between the two.
what is the roll-out on the tires , old vs. new?
Need to see what that it and then you can figure out if the new gearing will be enough to get you back to where you are now.
19/22 = 1.16 ratio
17/24 = 1.41 ratio
Circumference of the stock tire is 22.5". The circumference of the trepadore's is 26.5".
If I put the 24t as the pinion and the 17t as the intermediate or 17t as the pinion and 24t as the intermediate, this produces 2 different results? Maybe I am over thinking, but it seems to me it would be the same, just in different order
I think what really threw me off is not realizing you could go 17/24 or 24/17.
Tire is 16.3 % difference.
Gear change19.45 % difference.
Looks like 3.5% more gear , going to gain a little out of the hole and loose a little at top end.
Thank you for the assistance! I'll be on the level one of these days.
Not just a size difference, but mass difference too. The trepadore tires are a good bit heavier vs stock, that gear set should be pretty ideal to deal with the size and weight difference, even if a bit of top end is sacrificed.
I'm fine with sacrificing on the top end. I've never been a speed demon. I am boring and like nice controllable speeds.
Didn't think about the difference in weight/mass. Good point.
Breaking might be a little different as well. A little more rotating mass to slow down.
