I emailed DDM and this is the response I got.Ah gotcha. The clutch rubbing was an early issue with the vekta.5, I had the same issue so I talked to Steve at ddm and the solution was a Cy holder. If it was me I'd try to swap it, I don't really believe in adding shims.
I think I was confused on what the holder was vs what the housing is.A Cy clutch holder does tho and that's what I was refrencing.
You beat me to it. I was in the process of putting that same picture on here
