Hiya folks
Running my MT today and bought it in to give it a rest,pushed the cut-pff button and as normal the engine stopped,took the filter off and cleaned it then after 5 minutes pulled it to start.....Nothing!.....Pulled it again and again and again.......absolutly nothing,not even a pop or splutter.So went through the normal,plug,cut-off button,fuel etc.Pulled the plug out and the spark was healthy,put another plug in and still nowt.So went home and put another carb on incase I sucked some poop into the mill,pulled it .........NOTHING!!!!.Drained the tank,new fuel,same! Took the mill out set it up in my vice so that it would run as normal and took the cowlings off,unplugged the cut-off,pulled again......guess?.....NIL!
So i was contemplating cleaning it up and using it as a door stop for my workshop
Please fellow RCer's can you advise me on what I am doing wrong please as I'm no novice but this has got me beat.
Engine...CY 26cc
Carb....standard Walbro
spark plug...NGK
Fuel ratio....25-1 mix
Any help would be most appreciated.
Cheers in advance.
James.
Oh, and the bloke I recruited to large scale was with me aswell.Here he is first time out with his new Marder(shot on a fone:blush
http://www.youtube.com/watch?v=GbZhJTAtAs8
Engine...CY 26cc
spark plug...NGK
Cheers in advance.
James.
