corvette1941
- 0
I have a 1988 Raco Jackrabbit. I need to replace my carb on my Zenogh G2D motor. Does anyone know what carb could replace it.
I think the G2d came stock with the Walbro 167 carb ( Walbro WA-167 ). I think the new series of carbs will work with it. The older G2d's were 2hp motors where the new G230's are 2.5hp. The switch by Goped to the G23LH changed availability for your motor and discontinued it. Soon after Goped changed over to the more cost effective CY and the rest is history.
Here are some specs pulled for it:
Displacement: 22.5cc
Bore: 32mm
Stroke: 28mm
Piston Rings: 2
Compression: 8.4:1
Transfer Ports: 2
Reed: No
Carburetor: Walbro WA-167
Stock Carb Settings: 1/4 turn out both jets
Oil Mixture: 25:1
Horsepower: 2.0
Net Power: 1.2
Rotation (output side): counter-clockwise
Clutch Diameter: n/a
Ignition System: magneto with external rectifier/module
Idle RPM: 2750-3100
Max RPM: 18000
EPA Compliant: no
C.A.R.B. Compliant: no
Fuel Type: Supreme unleaded; 92 octane or higher
Could you post a pic of the carb that's on it? Or at least tell us what the numbers are?
Trip..
You can get kits for those carbs still if you want to rebuild it,you will need a primer bulb also,take it completely apart and soak it in laquer thinner for a day or two to disolve the varnish/old gas REMOVE ALL RUBBER PARTS BEFORE DOING THIS,they will swell from the thinner,those carbs are still used on some lawn and garden equipment,Shindaiwa I believe has a few on weedeaters up to 26cc.They can be a pain to tune sometimes,very finicy.
As Trip mentioned if you can give the center to center distance of the mounting screws,most are 31mm and also the throttle bore size on the motor side of the carb I can check the books at work and give you a close crossover carb.
Just for example the wt668 and wt817 carbs both have 16mm throttle bores,try to stick with a carb with the same bore.
One thing to point out since the motor has been sitting unused for a long time,more than 5 years I suspect,you should replace the crank seals as they are known to dry out from not in use and could cause air leaks,and siezure.
Hell of a first post!! Very informative!! Welcome aboard Jimmy..
WOW, I've never seen a rotary carb that big! What is the distance between the flange bolts? You may be able to use a butterfly style carb, I don't know..
Wow, I see whom to ask motor questions to!! :lol: It's not often a new member comes in here and knows more than we do!
Trip..
Thanks you Trip and Bigger the Better,It is a pleasure to be here.
It looks like this motor came with a few different carb options.A WA-167,WA-125-1 and looks like you have a WY-?,the WY is still available in several different bores,a WY-18 seems to be the closest to the one you now have,it is listed for 20-22cc motors,but is fairly pricey.Looks like the mounting screw holes are a standard size for these small carbs,all seem to be 31mm.The specs posted by Bigger the Better lists a WA-167 carb which is basically the same carb coming now on the CY(23-26) motor and some Zenoah(G230-G270) motors now,these have a choke plate built in as the 817 does not,usually uses a air filter mounted flap simlair to the WY,these have a bigger carb bore which will give you slightly more top end but you might lose some bottom end power.Might be the easiest way to go.
DDM lists them.
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.4409/.f
If you decide to rebuild the old carb you can use a K10-WY kit which is a complete carb kit with welsh plugs,fuel needle and gaskets or a D10-WY kit which is just the gaskets,but as noted the plastic carbs give a little trouble.
The complete kit runs around $15+ the bulb(maybe $4) while the new carb above is $37.
One thing,you can try a carb from a CY or a Zenoah if you have one or borrow from a friend,it should work for testing.
Norm for replacing the crank seals if you can have a leak down test done on the motor it will tell you if it is required,if you have not heard of or seen this done before,what you do is cover/seal the exhaust-intake ports with a plate and with a adapter via the spark plug hole pressurize the motor to 6-10 psi,if it drops quickly you have a leak,if it holds all is good,use a water/soap mix to locate the leak.If the seals have to be replaced you have 2 ways to go about this,take the motor completely apart and push the seals out from the inside or you can try to pry-pull the seals out from the outside but you must be very carefull not to damage the crankshaft and cases,I have even threaded small screws into the seal face and pulled them out this way.Seals are very cheap I just did both a CY26 and my Zenoah for under $10 for the 2 sets.
I prefer to use the lacquer thinner over the automotive carb cleaner because the automotive one has a rancid smell that will stick to you for days,the lacquer thinner takes a litte longer but works just as well I find..
James...
If you wouldn't mind James could you take a look at this post on this forum concerning a carb someone is selling.
https://www.largescaleforums.com/showthread.php?t=4861
I'd like to know if you think this carb will work for me for my Jackrabbit. Thank You so much, Norm
