fg monster and wheelies
lefnut
Active Member
will a fg monster truck do wheelies and if not what do you got to do to get it to do a wheelie thanks jeremy.
which tune pipe do i need im think about the ddm tour pipe or the high end pipe.
Tuned pipe and your good. I'm running the JetPro Silenced pipe and it's great. Not too loud for the neighbors, but way more power over stock.
im running the ddm top end pipe and it likes to wheelie, some times it gets to be a pain
he is a qucik vid with a fg mt and a ddm top end pipe
http://www.youtube.com/watch?v=eSuHgFYGcHM
hi m8,what engine have u got because i have just bought a second hand monster truck and the engine was poop so i bought the new cy 5hp angine and a jet pro v2 from ebay the guy was called bluefishy.com and i still cant get mine to wheelie.my gears i am running is 16t +46t ive tried tuning it but still no luck maybe im doing something wrong i don't no.your truck is tremendous by the way ive also got an fg baja that wheelies like that it wicked fun cheers ian
sounds like to me you got to much motor it probley just spenns out hope this helps.
im running a zen g270rc with ada manifold, stock 813 carb, gbe airfilter, 98 octain fuel with motul 2t off road oil, the zens rated at 3 hp and performs better the higher hp motors ive had.
you can see more in this post called so it begins
https://www.largescaleforums.com/showthread.php?t=4972
and ddm torque or top end pipe
https://www.largescaleforums.com/showthread.php?t=4600
Any stock fgmt with a 26cc will weelie with a pipe. You need to tune it or your tires are just spinning out.
or ity could be running to lean cause of the jet pro pipe it would loose power and not wheelie
the stock carb settings for my motor (g270rc) is
H needle 1 1/8
L needle 1 1/4
but after adding the ddm top end pipe i set the carb to
H needle 1 2/4 aprox
L needle 1 1/3 aprox
i had to chage the settings as it was running to lean and lost power, every time you add a tune pipe you need to ritchen the carb settings up
H needle 1 1/8
L needle 1 1/4
yeah it might be ive been trying to tune it for ages.ive also got a 1 second power delay witch ive been trying to get rid of but it wont go Ie: when i full throlt it from a stand still it takes off and then hits a massive power band at about 10/ 15 ft away so im not getting full power from the start.ive tryed riching it and leaning it but it seem to get worse but having the power band in it has got to be somthing to do with the tuning right. people please help its doing my head in and so my m8 he's pissing all over me with his beetle. :helpsmilie:
put a new carb on it or take your carb off and take it apart and clean it. or you might have a air leak.
Could also try putting a bigger spring in the clutch to allow it to spool up at low end. This will give you more power off the start.
When you hit WOT at the start does it spin the wheels.
engine i am useing and exhaust
what motor what pipe and whats the carb set at now ?
cy 28.5 cc PORTED- TUNED ENGINE from oneillsbrothers.com
free airfilter kit/ clutch /when you purchase this engine
THIS ENGINE IS SOLD BY OTHER SHOPS IN THE UK FOR £220.00 IN A STANDARD UN-TUNED VERSION WITHOUT A PERFORMANCE FILTER KIT
MY BARGAIN PRICE IS 239.00 FOR A TUNED VERSION
CY 28.5cc (29cc) THIS IS MY BEST SELLING ENGINE AND IS VERY POWERFULL IN THIS TUNED VERSION( new version with improved head design with a thicker cylinder base and machined crank cases to match...see pics)
THIS ENGINE AS BEEN SPECIALLY PORTED.. THE EXHAUST AND INLET PORTS HAVE BEEN ALTERED
WITH IMPROVEMENTS TO THE TRANSFER PORTS..
36mm BORE 28mm STROKE (STUFFED CRANK)
THIS NEW COMBINATION OF LARGE BORE AND SHORT STROKE LETS THIS ENGINE PRODUCE GREAT BOTTOM END POWER AND STILL ALLOWING HIGH RPM USE ,revs higher than a 29cc engine with 2mm stroker crank!
ALL CHROME COVERS
FACTORY FITTED STUFFED CRANK.
PRODUCES 5 HP WITH STOCK EXHAUST......OR ABOUT 6+HP WITH A JETPRO PIPE .....
COMPLETE WITH WALBRO WT-668 CARB*
PLUS FREE
CLUTCH SHOES AND BOLTS
K&N STYLE PERFORMANCE CHROME AIR FILTER.
ALLOY 17mm VELOCITY STACK
ive also got ba jet pro v2 race exhaust = the carb settings at the moment r H 1
L 1 + just over 1/4
