will a fg monster truck do wheelies and if not what do you got to do to get it to do a wheelie thanks jeremy.
im running the ddm top end pipe and it likes to wheelie, some times it gets to be a pain
he is a qucik vid with a fg mt and a ddm top end pipe
http://www.youtube.com/watch?v=eSuHgFYGcHM
hi m8,what engine have u got because i have just bought a second hand monster truck and the engine was poop so i bought the new cy 5hp angine and a jet pro v2 from ebay the guy was called bluefishy.com and i still cant get mine to wheelie.my gears i am running is 16t +46t ive tried tuning it but still no luck maybe im doing something wrong i don't no.your truck is tremendous by the way ive also got an fg baja that wheelies like that it wicked fun cheers ian
or ity could be running to lean cause of the jet pro pipe it would loose power and not wheelie
the stock carb settings for my motor (g270rc) is
H needle 1 1/8
L needle 1 1/4
but after adding the ddm top end pipe i set the carb to
H needle 1 2/4 aprox
L needle 1 1/3 aprox
i had to chage the settings as it was running to lean and lost power, every time you add a tune pipe you need to ritchen the carb settings up
what motor what pipe and whats the carb set at now ?
put a new carb on it or take your carb off and take it apart and clean it. or you might have a air leak.
