Single Steering Servo
I don’t have one. I have a stock servo with a stripped gear. If the s9020 gear set would fit I could swap it out and cost much less
Gotcha. I've tried with a few other spectrum servos I had lying around to no avail. They all looked the same but differed slightly in size.
Good to know, I might order a set just to try and if they don’t fit I’ll order the whole servo and just swap it out
Cool, post an update when you do. I'm curious if it'll work as well.
Will do. Also, I am going to pull the gear out that has a couple broken teeth, there’s a pin on it that limits how far it can turn, so I’ll pull the pin and mill another hole 180° from where it is now and I should be good. It just so happens the two teeth that broke are 180° from the pin
Damn why didnt I think of that. That'll get you back up 100%! I've got a few of them in the bin, I didnt trash em for a reason. But hey, don't forget to loosen the servo saver or you'll strip gears no matter what servo you use.
All depends on where yours are broken. There’s a special shape that the gear sits on that only allows it to go on two ways. The right way and the way where the pin wouldn’t allow you to put it back together.
Yep! They all pretty much break in the same spot with the servo saver cranked down. All it takes is 1 good cartwheel.
Well I guess that’s good then. Too bad they didn’t already have a hole for when that happens. It’s a good thing I’m a machinist and have access to a Bridgeport. Though I’m sure it could simply be done with a hand drill.
Did you end up just switching servos?
Yes I have to be the hardest person on servos. I put a Hitec d845wp in there. Thought problem solved. Nope. Just the other day it quit working, so I sent it in for warranty. Now I am giving the Hilatronics Hercules black case a try. Been hearing good things about it and it's specs seem awesome. Should be here tomorrow, so I will get it installed for the weekend to try out. Maybe I may have luck with it. Check this out.. https://www.detroitperformancerc.com/product-page/hilatronics-high-torque-smart-servo
20190419_190912.webpGot it installed last night. Of course it's pouring rain outside.
