BoostedTRex
- 2
I’m talking just the gears, they appears to be the sameIt will not, and you would need the futaba brackets to fit the s9020. The redcat servo setup is similar to spektrum, but not identical.
I don’t have one. I have a stock servo with a stripped gear. If the s9020 gear set would fit I could swap it out and cost much less
Good to know, I might order a set just to try and if they don’t fit I’ll order the whole servo and just swap it outGotcha. I've tried with a few other spectrum servos I had lying around to no avail. They all looked the same but differed slightly in size.
Will do. Also, I am going to pull the gear out that has a couple broken teeth, there’s a pin on it that limits how far it can turn, so I’ll pull the pin and mill another hole 180° from where it is now and I should be good. It just so happens the two teeth that broke are 180° from the pinCool, post an update when you do. I'm curious if it'll work as well.
All depends on where yours are broken. There’s a special shape that the gear sits on that only allows it to go on two ways. The right way and the way where the pin wouldn’t allow you to put it back together.Damn why didnt I think of that. That'll get you back up 100%! I've got a few of them in the bin, I didnt trash em for a reason. But hey, don't forget to loosen the servo saver or you'll strip gears no matter what servo you use.
Well I guess that’s good then. Too bad they didn’t already have a hole for when that happens. It’s a good thing I’m a machinist and have access to a Bridgeport. Though I’m sure it could simply be done with a hand drill.Yep! They all pretty much break in the same spot with the servo saver cranked down. All it takes is 1 good cartwheel.
Did you end up just switching servos?Ya junk metal. I stripped 3 of the 9020 gear sets
Yes I have to be the hardest person on servos. I put a Hitec d845wp in there. Thought problem solved. Nope. Just the other day it quit working, so I sent it in for warranty. Now I am giving the Hilatronics Hercules black case a try. Been hearing good things about it and it's specs seem awesome. Should be here tomorrow, so I will get it installed for the weekend to try out. Maybe I may have luck with it. Check this out.. https://www.detroitperformancerc.com/product-page/hilatronics-high-torque-smart-servoDid you end up just switching servos?
On the servo saver should the nut be up or down?Yep! They all pretty much break in the same spot with the servo saver cranked down. All it takes is 1 good cartwheel.
