Ninth Island RC
- 71
Yes, I am aware that MIke is working on a layshaft specific to the VESLA (not going to say I am the reason...but, I'm willing to bet that I'm one of the people that led him to doing this). Anyway, as we don't know how long this will take, and me wanting to do this now, I started questioning whether, or not, the Taylor RC layshaft & spur carrier (both of which were designed specifically for the gas VESLA), along with the Blackbone Baja gears, could be used in an electric VESLA. A lot of people said this couldn't be done. They said it isn't possible. In contacting Taylor RC, I was told it won't work. I even had one individual (who I'll refrain from naming) tell me there's no way it will ever work. Only one person, Brian Bailey (on FB), believed in the possibility. So, between countless back & forth messages, we attempted to determine IF it was a realistic possibility...and, if so, how realistic of a possibility was it. He has a gas VESLA (which he's since converted to electric, but is still running some of the gas-specific parts), as well as the Taylor & Blackbone parts in question. We each took several measurements...him measuring the stock gas & Taylor RC parts, and me measuring the electric parts...and, it was determined that there WAS a realistic possibility that it SHOULD work (not saying it 'would', only that it 'should').
At that point, I decided to take a chance, and ordered the necessary parts - the Taylor RC layshaft & spur carrier, as well as a Blackbone Baja Spur & Pinion set (obviously, the included pinion wouldn't used...just haven't yet decided what to do with it). Not that it matters for the purpose of this post, but, for the Blackbone gear set, I opted to go with the 56T/19T combo (there are other combos available, from a 57T/18T, up to a 53T/22T). Anyway, as you'll be able to tell from the photos, below, this idea that I had...this idea that several naysayers said wasn't possible...Brian & I have proven IS possible. Not only that, but, NO modifications to ANY of the Taylor or Blackbone parts were needed. The only mod needing to be done was to the Kraken gear cover (which I'm still devising, as it needs to be extended by at least 4mm where the layshaft hits the cover). Additionally , a spacer of the proper length (in this case, "proper length" means it needs to stick past the end of the layshaft by a minimal amount...say, at least 0.5mm, although 1mm is better) needs to be added between the spur carrier, and the bolt at the outside end of the layshaft. This is to "lock" the carrier & spur into position, preventing the carrier from sliding away from the transmission.
As you can see, the slipper HAS been successfully removed from the equation on an electric VESLA, and it IS possibly to use the Taylor RC layshaft & spur carrier in an electric VESLA. I am not trying to put the naysayers down (I just wanted them to know if can be done)...but, to all those who said "it's not possible", to quote one of my favorite movie lines, "You have been weighed; you have been measured; and you have been found wanting.” So, for those interested in going this route, but not wanting to wait until Mike releases the electric version of the latshaft, the spacer mention should be no shorter than 21.5mm, and preferably no longer than 25mm (to make certain that enough of the bolt threads are seated deep enough into the end of the layshaft). For mine, I cut the spacer to 22mm, which (as you might be able to tell from the 3rd photo) placed of approx 1mm beyond the end of the layshaft.
