I have not used their housing before, but two things come to mind.Anybody tried using FID Racing aluminum housings and had trouble getting the bearings to fit in the pocket?View attachment 107498
I’m sure this is quite late to suggest but I’m a mechanic and rebuild transmissions and diffs. If you toss the bearing in the freezer for a couple hours it’ll drop right in place. If you want you can even heat the housing in the oven for a few. Or reverse it depending on setup.I have not used their housing before, but two things come to mind.
If you know you have the right one for the DBXL-E 1.0 and the bearing is the right size... if can always be hard to get a new bearing into a NEW aluminum housing.
When I know all is right when it comes to metal diffs, knuckles\steering blocks, etc. I add a little lube on the outside of the bearing and the inside of the diff. I have a socket that has the same diameter as the bearing outer ream. I take a small hammer and evenly tap it until it sits flush and flat.
